Dave & Amphi - it's actually the 185/
70R15 which is available (old M471 option size) & 195/
65R15 that is close to our size & was a factory recco back when the 165/155 sizes started to disappear or were mostly gone. IIRC Jeff Bowlsby has that letter on his classic 914 website somewhere under rare documents or one of the other sections. Also IIRC that letter had a recco for adding some steering bumpers to restrict the lock-to-lock turns of the front wheels to prevent rubbing contact on the fender &/or inner wells (esp. on compression in a bump or outer side on a turn). 195/60R15 is available, but I've not seen 185/70R15's for eons!
Go to the 914 Info section above then to the Tire Size Calculator on there & it will give you the speedo/odo error on any size tire from the original ones on your 914, so look at the tag on the gas tank top at the evap/filler area to see what the original tires size was on your particular 914 & matches the speedo/odo gearing in it. BTW - the old 165 & 155 tires were generally considered to be roughly an 80 cross section (80% width to height of cross section) - i.e.: 155(/80)SR15, 165(/80)HR15, etc. - which is the case to presume when no /## cross section is indicated on a tire (so 185R15 will be too big & tall for a stock 914 at a presumed /80 cross-section, etc.)
I don't know what engine/model you have, but the early 1.7L 4's had 155 or 165 SR's, then in 73 MY they all were upped to 165SR15, whereas the 914-6's & 2.0's had 165HR15, except 6's with the M471 or GT package had the 175/70VR15's. There's several posts in Originality & History on tries & current availability.
Here's a short bit of it Amphi - those Michelin XZX 165SR15's are still available through Lucas, Universal, Vintage & Coker tires - check for best prices. They also carry the less costly vintage repro style Vredestein in 165SR15 & 165HR15 ($105+/- ea.); as well as the much pricier original retro vintage Michelin XAS 165HR15 ($300+/- with tubes ea.), Pirelli 165SR15, XZX 165SR15 noted above, XWX 175/70VR15 ($400+ ea.
) - all are pretty pricey & are NOT really good snow tires if yours is an all weather DD (most aren't bad in wet.
If yours is a DD & you want to up size to 195/65R15 in either SR, TR, HR or VR speed rated tires - then there are a plethora of choices form $50-70 ea. up to the $100-200 range, & in M&S, 4 Season, Winter/Snow, Performance, HP & UHP flavors, from Everyone from the "unknown brands" making their own marque as well as for the majors (like Kelly-Springfield used to do for Bridgestone, etc.), up to Yokohama, Kumho, Bridgestone, Michelin, Continental, Dunlop & Goodyear (Dunlop is now just a US brand of G'year), etc., etc. You can get these online for godd prices from Tire Rack & shipped to you for local installation, or from your local trusted tire shop directly.
Generally for street tires on a DD or less regular driver the choice will be as much personal choice & what your needs & uses are, as well as whether you plan to compete in any PCA AX &/or concours events, etc. Several other classic/vintage Porsche owners whom I know swear by the Vredesteins, XZX & XAS, etc.; as well as the 195 sizes by Bridgestone T550's & Kumho's (perhaps the most bang for the buck in cost vs. performance), Yoko's, Falken, etc. If you're going to use your 914 in TN in the winter & want the 195s, then you may want to look at 2 sets - one P, HP or UHP for hot good weather driving, & another set of winter tires on other wheels for tougher duty in snow, slush & ice.
I don't recall if TN allows studded tires, but most states don't, so the newer winter/snow tires have a "grit" incorporated into the rubber compound at the tread for that purpose, which makes them more skittery on dry pavement - esp. in a better handling sports car. whereas, the 4 season & M+S ones don't have the grit & are better balanced performance in all weather - a little less sticky in dry & a little less traction in snow - but better all around & less cost than having 2 sets plus changing them out. I run an off-brand National M+S on my BMW 325e to good effect, with little traction difference from the OE Michelins but better in the wet (we do have some rain out here in CA
The UTOG # & Traction Rating will give you an idea of how stick/soft the rubber compound is - with 200-400 made for stickiness & 400-600+ for longer wear - but that does not necessarily translate to better performance, since some Kumho's have a 400 but handle better than some Goodyear/Dunlop with 300's. Another indicator of better perfomance will be to step up in speed rating - you had SR's for up to 115 mph rated, whereas the 2.0 & -6 had HR or VR (139 & 159 mph respectively) - T rated is 125 IIRC but wasn't around "back in the day") - so they're built to withstand & handle at the higher speeds on an extended time basis, & the same tire in HR will handle better than its SR sibling, etc.
Also make sure to read the tires' sidewall - preferably before they install & you pay - to make sure they're not passing old stock off on you which will have a shorted useful life &/or warranty, than you will typically need when you next need to replace - see here:
http://www.discounttire.com/dtcs/infoSidewall.dosHere's info on those ratings etc.:
http://www.discounttire.com/dtcs/infoHome.dohttp://www.discounttire.com/dtcs/infoTreadwear.doshttp://www.discounttire.com/dtcs/brochure/...Speedrating.jsp
