$100 for front
$100 for rear.
I'll get pics up this evening, sorry I left my camera at home.
Rear comes with bar, "U" mounts that go under rear trunk, drop arms and shock bolts with balls on them. So everything you need to install.
Front comes with bar, both drop arms, both triangle bushing supports, but no "U" tabs that mount on the "A" arms or course. One of the arms has a slight bend in it, easy to straighten.
Should be noted all bushings should be considered "shot" as they are old and worn out. Yes, you could use them, but wouldn't want to sell these under the impression they are in good shape. They should be replaced.
Parts are kinda dirty and crusty (Surface rust), nothing bad at all, just make the parts look kinda ugly.
I will get pics up this evening.
I can ship, but given the length of the items, it won't be cheap I'm sure.
