so I'm driving the 914 around today...
Plano does NOT have the smoothest roads, there's tons of bumps that are expansion joints where the roads were repaired, etc...
every bump is causing a squeak in my car... sounds like it's coming very near my driver's side door, or a little behind. hi-pitched, short squeak.
any ideas?
also, my driver's side door decided to lock me out for a bit I had locked it when I went into work, and when I came out the key wouldn't turn in the unlock direction... turns fine in the lock direction...
so I climbed in from the pass. side, the door still wouldn't open... so I gave up started the car... try once more... opens right up...
anyone ever seen this before?
