QUOTE(Britain Smith @ Apr 1 2010, 12:01 PM)
Yep. I have always wondered how my 914 would do with that amount of power! Gotta build a supercharged 911 engine.
-Britain
So you'd have to be be running a twin turbo 2.2 (and a bit) to stay under the 3200 OHC limit with the 1.4 multiplier. Twin turbo's would surely put out 300 or 350 hp, so very competitive.
And we know the guy who could build one... but hopefully faster than the last turbo motor.
The only problem would be weight, with the Sprites (at 1600#), if I'm reading the rules correctly.
So maybe they have a 100# advantage.... nothing a good 914 driver couldn't overcome.
References:
page 139 - SCCA rule book
5. For weight designations in EM, Mazda rotary engines are compared
to the piston engines listed (i.e., 3.2L OHC vs. 4.5L OHV).
13B rotary engines should be equated to the 3.2L OHC engines.
13B forced-induction rotary engines (1308cc x 2 x 1.4 = 3662cc)
and all 3-rotor engines shall be grouped with vehicles required to
meet the stated 1800 lb. minimum weight
page 224
MODIFIED CLASS E (EM)
Modifi ed Production and GT cars as follows:
A. Weight (with driver) vs. Displacement
Piston engines up to & including 3200 cc OHC: 1700 lbs
Piston engines up to & including 4500 cc pushrod/OHV: 1700 lbs
2-rotor rotary engines w/ unrestricted porting: 1700 lbs
Piston engines unlimited displacement: 1800 lbs
3-rotor rotary engines w/ unrestricted porting: 1 800 lbs
B. Performance Adjustments
AWD: Add 300 lbs
Modifi ed Tub: Add 50 lbs
C. Weight Bias Adjustment - with driver sitting in the driver’s seat
RWD w/ less than 51% weight on drive wheels: Deduct 50 lb
FWD: Deduct 50 lb
MODIFIED CLASS F
