I started getting a significant miss above 3k rpms so I started troubleshooting. Immediately found the #2 wire was all corroded in the distributor cap so I swapped out the wire and now I can't get her to start. The engine started and ran great previoiusly.
It's a stock 74 2.0 with original FI
Checked points, cap, rotor, coil- all good.
Replaced all 4 plug wires and coil wire.
Swapped cap.
Double checked the firing order- it matches up. here
Now here's the kicker. When I swap 3 & 4 on the cap, then engine fires up immediately. It's really rough so I know it's not correct. Same thing when I swap 1 & 3. To double check I had #1 located correctly on the cap, I started rotating the 1-4-3-2 order clockwise around the cap. At 90 degrees it only cranks about 3/8 of a turn of stops. At 180 degrees it starts and runs rough. At 270 degrees it does the same 3/8 of a turn and stops.
Back at the correct order, it cranks freely but acts like it's not getting any spark. The distributor nice and tight so I know I didn't bump the timing.
Any thoughts?
