QUOTE(Pat Garvey @ Apr 2 2010, 05:28 PM)
Sorry Tom - couldn't help myself!
Is that the best yu can do for spider webs? Geez, I have 3 on leashes & six more with flea collars! Don'y think Spidey lives here - ask Ferg!
Pat
BTW all y'all - is it safe to clean the engine & trans case, suspension & shocks, etc. from years of oil leaks & road grime with POR Marine Clean, or is that too strong for the paint, aluminum & magnesium alloys, etc.?? ... &/or other safer cleaner suggestions?? OK - OK - needles to say (pun intended) - other priorities Pat, like getting rockers off (good at both longs!
), & trying to strip to shell & get pix for bodywork estimates, etc. Getting close to doing a post in garage for SoCal body shops to give me estimates (& McMark if not too much $$ to ship 2 shells & travel up there to Napa during process - as it's about = NYC - Atlanta distance-wise).
Engine/Trans will come out as unit at my mechanic for refresh, while I do tins, etc., & while this shell-roller & ex-racer donor shell go to TBD shop for paint & body!
If I ever get any CW entries on this 914 when it's done, then I should at least get a
for "resurrection from the dead" from where it's come! Just pulled inner door seals on both door & found bad rust on the bottom skins above the seal (seal covered it), the donor pass is clean, but driver is also holed there but not as bad - so now I need to find a local late L door that's clean!
Oddly enough - it appears from peeking behind the inner panels on this 8/72 &# MY 2L - that I have a new 3rd door type on it - a "Light Late"!!
It appears to be the late regulator & inner framework, but lacking the side impact reinforcing bars welded between the outer skin & inner frame (I can see them on the 74 donor shell's doors & know what to look for & where, but nada!) ~ & no CW's, they were never lightened by anyone removing them & doors were original to the vehicle!
... probably just one of those early-73 MY anomalies which extended to the first 1-2,000 cars built!
BTW - with all the El Nino rains - we're having a killer Black Widow season out here, & I was almost attacked by a humongous one when looking for the hide-a-key under the Honda my daughter drives everyday - to get it's Alt. replaced!!!!
... not sure which of those are "active" or not - so I shoot with the zoom when I can & approach with caution!
PS - this is why I got such a giggle out of Steve G's prolific apologies over how "dirty" his Sahara's engine & underside was!!! I mean look what I've got to get into shape - even rust on the cylinder heads' fins!!!
... don't know whether to
or
or
