QUOTE(ruddyboys @ Apr 2 2010, 01:52 PM)
How do I remove the back trunk lock. Not the cylinder the whole lock.
There are 2 10mm bolts on the upper latch, 2 10mm bolts on the lower latch, and then a big nut holding the whole lower assembly / spring lock. I've used plyers to get it moving (hopefully yours isn't on too tight) and work it off from there...
