There are several scenarios when you have flasher (turn signal or hazard light) problems, and with each I have posted a probable cause. They are in no particular order:
1. turn signal and hazard lights do not work everything else works:
Flasher relay is bad or improper three prong type installed
2. hazards work but only one side of the turn signals work: turn signal switch is bad and not making connection
3. rear lights do not flash brightly: rear ground wire bundle on the drivers inner fender well is not making good connection
4. front parking light side of dual filament bulb is brighter than the flasher portion of the bulb: wires are plugged in backwards
5. 70-early 74 both arrows flash when turning left or right: wrong bulb installed, battery voltage low, ground lead not making connection
6. hazards work but turn signals do not: turn signal switch disconnected or bad
7 fuse blows with turn signal is applied: ground wire has been switched with the power wire at the assembly
Please remember that most flasher problems occur after the 914 is reassembled after painting and the technicians do not know which wire plugs onto what terminal. "Tech Tips 700" has a good written guide on how to replug the leads.
