QUOTE(Dr Evil @ Apr 4 2010, 03:20 AM)
Jeez! $400 for a GA set? I wish I could get that much for them, I have had a few.
It's not a bad price for a mainshaft and a gear, if you need a mainshaft.
3) Find the correct sporto tranz and use the r/p out of it as it is a shorter one...
I think most of us would call that 'taller' but no matter...
The gears that Mark was talking about are probably a Z gear which is a stock 5th in a /6 box.
stock /6 top is ZA (/4 is ZD)
Another but not immediate option is that Guard Transmission is finally making 901 gears. Tell Matt what you want and when demand reaches cost to supply, it can happen. The advantage of this approach is that you can finally have a 'flipped H' ratio with the correct helix.
