QUOTE(ericread @ Apr 5 2010, 11:59 AM)
QUOTE(realred914 @ Apr 5 2010, 11:05 AM)
first off there are at least two versions of the temp gage with differnt red zones, early cars had a bigger red zone that kicked in sooner, later cars had a smaller red zone. as far as i can tell the gages work the same, so the factory upped the red zone. (maybe cuase they heard complaints about being int he red zone from owners???)
at any rate on warm days (75F +) at high speeds 70+mph specailly going up hill my oil temps gets high, at some where around 230F you will note a drop in oil presure, leting off the gas and slowing down will restore the temp to lower.
the mid point of a couple stokc gages I tested with a thermocoule is close to 220F.
i would stoongly urge you to add a oil presure gage if you dont have one. if youget so hot oil pressre drops then fro sure you need to let it cool down
head temp is also nice to have as it resonds to temp s fast
even thouhg I have cleaned all junk off eh cooling fins ans sealed all engine seals well mine still gets hot when under load for long at 3500 rpm +
could be function of timing mixture compresion ratio ect... also
Since everybody here is a much better expert than I, I do not want to challenge other people's post, but I felt I should add my opinion.
As for the oil temperature, let's say that everything above is absolutely calibrated correctly. For me it represents a lagging indicator. It takes from 15 to 30 minutes for this sensor to give you information abnout what the engine is doing now.
The oil temp gauge is useful, but not to measure current driving conditions. The CHT on one or more spark plugs will give you the current temperature of your engine, which you need if you are concerned about your engine overheating. Waiting until your oil temperature peaks is way too late, the damage has already been done.
My other issue is with the oil pressure dummy light. If this light illumunates, you are screwed. Your oil pressure has dropped and your engine is in danger. I agree that an oil pressure gauge would provide a better measure of safety.
But for me, I rely on my tachometer, my CHT, my voltage gauge and my fuel gauge. The rest of teh stuff looks pretty, but I don't drive by them.
Eric
yes, but an head temp sendor will not tell you anything is wrong if you loos oil pressure until it is too late. an oil pressure gage is great to tell you if your oil is sloshing to one side and missing the pick up tube in hard corners, you will see a momnetary dip in pressure, you wont detect that with a temp gage oil or head temp.
all in all if there was one gage, oil pressure wouldbe my first choice, as it gives some idea of too high a temp (pressure drops when hot) and will also tell you if you have oil system problems like low oil level such that oil is not at pick up tube when corninging or stopping fast. sloshing oil is a big deal on a 914, even when topped off they can starve of oil in a corner, be a half quort low and the probelm gets much worse in a corner.
next gage in order of preference is head temp, then finally oil temp.
my oil temp gage will show high oil temps sooner than 15 minutes from start if driven hard.
remeber a blocked oil cooler will raise the oil temp too much yet you may not see that much of a probelm on teh head temp, meanwhile you oil is cooking.
best case is to get all three gage, but money some times reuires compromise, hence the ranking of importance. funny how factory offered the least practical of the three gages.
