QUOTE(rick 918-S @ Apr 4 2010, 08:52 PM)
I'm installing the column in Sandy's car. It has a washer switch with two hoses connected to the column switch. Anyone know which hose connects to the "P" side of the switch? One hose has an orange stripe on it. Is that the "P" pump hose?
Rick - I usually just use the p-hose for long trips where I don't want to stop!
In deference to my esteemed 914 colleagues on here, I think that the spare tire air pressure system has always worked fine for the 130k in my 914 since I've owned it, and the hoses are cheaper to replace than a pump! It also forces you to keep track of your spare by having 40 lbs. in it, & when the squirter dribbles (so to speak!
) then you know it's either low on air or a hose is loose or cracked. It's the perfect K.I.S.S. solution for this situation, and saves the weight & complexity of a pump system.
... that's my 2 bits worth anyway (inflation & DM to Dollar devaluation since the 70's)!
