Larouex
Apr 5 2010, 10:45 AM
Added 4.18.10
Sold everything
I have a Warp 9 motor, brand new and the Electro-Automotive Mount and Adaptor for the 901 for sale. Everything you need for that awesome EV Conversion.
Make me an offer, I am here in Seattle and locally would be ideal, the motor weights alot!
Send me a PM if interested.
Larouex
astronomerdave
Apr 6 2010, 08:24 AM
You may want to try posting this on the 914EV google group,
http://groups.google.com/group/914evand/or on the EVDL (http://www.evdl.org/).
Best,
Larouex
Apr 6 2010, 09:10 AM
Everything you need to convert and mount an Electric Motor in a Porsche 914.
Motor - Original Cost = 1700
Adaptor to the 901 Tranny - Original Cost = 850
Motor Mount - Original Cost = 80
My Sale Price for the Whole Setup is: $1200 OBO
I have the Netgain Warp 9 Motor - Never been used, great motor...
* - 9.25” diameter, series wound DC motor
* - Weight, approx. 156 pounds
* - 28.8 HP (72 Volts, 335 Amps)*
* - 70 Ft. pounds torque*
* - 5,500 RPM's
* - Double or single ended shafts
* - Advanced timing – factory set for CCWDE (CWDE available)
* - Industry standard mounting and bolt configuration
* - Commutators key locked onto the shaft
* - High quality, large style brushes, factory preseated over 90%
* - Exceeds Class “H” insulation
* - Drive and tail shafts keyed with pilot bearing hole
Adaptor from Electro-Automotive
The adaptor plate mounts the electric motor to the original manual transmission and clutch. The Electro Automotive adaptors are precision machined on order from our library of patterns. There are shipped ready to install - no further work necessary. The adaptor comes in four parts. The transmission profile plate is machined from aluminum, and mimics the original engine mounting surface. The motor spacer ring is also aluminum. It mounts to the profile plate, and recreates the original spacing between the flywheel and transmission.
