QUOTE(JRust @ Apr 5 2010, 08:41 PM)
So I just went to pull my close to perfect rear bumper top. Damned if both ends bolts didn't break
. Anyone have a wat to replace without screwing up the bumper top? It is one of the nicest I have found besides
Just did it! I had a bumper in storage for many years. I pulled the top pad so I can fix a couple dents in the bumper and repaint it. All but one nut came off. One snapped off. I drilled it out and installed a new stud with JB weld. You really can't tell which one it is. I just cut the head off a bolt and used a grinder to rough up the section I installed in the new hole. This way the JB would have something to hold on to. A word of caution. Use a center punch and get the hole set in the right place. Take your time drilling. Be careful when the drill breaks through the metal and hits the rubber core. I can see where it would be easy to run the bit right through to the face.
I knew I should have documented it..
