So this weekend I was trying to strip out everything from the interior for a shell repaint, but got stuck on the Pass. side front wall carpet section because it has an eye for the steering column.
I tried just removing lower Steering column U-Joint to try to lift it off over the section to the ZF rack, but there wasn't enough play, even when I tried rotating the wheel so that the upper u-joint was aligned to move in the needed direction!
So is there any easy way to get that u-joint off of there, without pulling rack or wheel?
I'm trying to tackle things one section at a time, and am not ready to pull the steering wheel nor ZF rack, so if there's no easy way - that'll have to wait. It seems that they should have some easier way to install/remove that carpet, short of pulling a steering wheel or rack!
