I have a 73 914 and I need to find the ballast resistor to check it. Is it in the plastic casing where the spade connector is?
Also, I am just learning how to tune it, as it sat for 6 months while I completed all the fuel pump hose replacements.
I know the FPR should be at 29psig
What is a good setting for the points? plugs and dwell/timing?
The car is running really rich. All the MPS/ECU and harnesses check out electrically
I am replacing all the relays as the cheap ones from China expand and go dead when the engine warms up.
I do most of my own work and just bought a timing light, dwell meter, fuel pressure gauge and vacuum gauge.
I have a vacuum leak where the decel valve goes into the MPS, but it is not terrible.
I know the FPR has to be set, but could that be the major reason for the rich when hot reaction?
Also, do I need a flow meter for the throttle body to get this really idling and running more to a lean side?
I am way out of whack, but it runs and needs wise TLC.
Just joined!
This is my 6th 914 2.0, but I never did tuneups. Have rebuilt several short blocks, but always left the adjustments to others. Now the costs are too high and I really should know this stuff better.
Thanks, any who respond!
JPL
