QUOTE(Tom_T @ Apr 11 2010, 12:47 PM)
QUOTE(tod914 @ Apr 11 2010, 08:26 AM)
Just buffed out and polished some small pieces I refinished with the satin trim paint. Looks real good. I noticed that there seems to be some variance on the factory tin color. Either one, don't think you could go wrong. Once I get the car finished I'll post some shots.
Tod, Pat, Paul, et al CWs .....
Isn't it basically the same color/tone/finish black paint used on the engine tins, airbox/air-cleaner, fuel tank/expansion tank/vapor-cannister, suspention parts etc. which were originally in that semi-gloss black??
... or are we going to be hunting down the "proper black" for each of those?
It seems to make some logical sense that Karmann & VW/Porsche would've used the same black & grey paints on all of their components painted that way respectively.
BTW Tod, the resto guy's (my post above) suggestion on keeping the bare metal engine bar from rusting is to do a satin or flat anodizing, which should still like like the raw metal. He said they've done that on some 914-6's that they've restored.
No, the air cleaner was a a semi-gloss.
Expansion tank shade is a function of your production cycle - some were satin, some were semi gloss.
Late 72 tanks had a gray/brown/black semi gloss finish.
Some pieces of the plumbing for heat were painted a slate/semi gray.
The enigine bar WAS bare metal, which oxidized overnight. It was ill-thought. Replacing the rusty piece with a satin black piece seems to make sense to me, which I did in '89. Nope. not factory original,and I rearely make exceptions, but this just seemed right. If you anodize it, a judge can spot it a mile away. Don't waste your money, because you're going to get gigged anyway. Go for purty!
Pat
