I'm in the process of cleaning and preparing an old 2.0 engine for 24hr of LeMons. I have removed all the tins to clean the fins and remove all the trash accumulated over the years. I have removed the front blower section and cleaned the fan as well. Replaced the oil cooler seals. I would like to block off the heat exchanger tubes. If I remove the "J" tubes and block off the holes coming off the blower housing will that help? Is there any advantage to leaving the "J" boxes and running air through the heat exchangers?
Since I have everything off the front of the engine, am I able to inspect the oil pump by removing the cover below the crank? Front oil seal is dry as a bone, should I replace it just for good measure? Any other input is appreciated.
