QUOTE(jeffdon @ Apr 9 2010, 10:35 AM)
See attached....I believe the correct installation is with the V (red line) facing up, so that the downward bent flange on the tin will rest in this V. Am I correct?
exactly as you said, Vee down is it!!!!!!
remember to use a big staple or a bit of bailing wire to tie off the two front most corners (the side pieces to the front peice) the factory had a big staple thru them to finish off the seal nice and tight.
