I'm not clear on what you have, exactly.
Your gauge is ______ psi.
Your sender is _____ psi.
I was just researching this for SirAndy. Both senders have a range of 0-180 ohm.
If you have a 5 bar sender and a 10 bar gauge, the gauge will read fine, but you'll have to mentally 1/2 the numbers you see on the gauge.
If you have a 10 bar sender and a 5 bar guage, again, the gauge will read fine, but you'll have to mentally double the numbers you see on the gauge.
If you have a dual contact (pressure and warning light) 10 bar
sender that you don't want, PM SirAndy because he's going to be buying on and you might be able to work something out.
