QUOTE(Backdraft @ Apr 11 2010, 12:37 AM)
Hi all,
I'm a new member, so go easy if you will. Anyways, I'm currently a university student working on a class project for a professor/teacher, which just so happens to entail his modded 914 (see more
here).
In a nut shell, he has already bought a front-mounted oil cooler for the 914, but does not know the optimal shape/size of the holes in the front bumper/valance area and the front floor in order to provide the right amount of airflow to the cooler, yet still preserve as much aerodynamics and lowered drag. He has tasked us to figure this out (using Solidworks/Flow Simuation, and a real-life water channel experiment using a 914 scale model), and suggested this forum for advice.
Anyways, has anyone done/looked into anything similar for their car, especially modifying the front fascia area to increase/promote better airflow into an radiator/cooler, and what kinds of results/consequences you noticed? It doesn't even have to scientific at all, I was just fishing for different ideas of how some drivers may have modified their cars especially to promote aerodynamics and/or better airflow in the frontal area.
This is mainly an autoX car, so huge ass fins or wings won't be that important. I'm more looking for slits or opening modifications to the bumper/fascia.
Thanks all for your help.
Out of curiousity, would/could you provide some rough dimensions for your front bumper/valence slits (ie. size and shape), as well as any reference points they are located from (ie. from the ground, front trunk floor, etc.). Also, was that air dam custom built or was it a part that ordered from a catalogue (ie. Patrick Motorsports)?
Hi Backdraft,
In spite of the fact that you gave me NOTHING , I’m happy to share all the amazing technology of the front-end of my car: (just pulling your chain)
-First off, you can see that I have the hood removed as I finish my transition from bottom to top exhausting.
-The nose-piece is a standard product from Rennsport.com, Monrovia, CA, but they appear to be out of business.
-The splitter I made myself from 12” thick honeycomb stock and formed the leading edge with Bondo. It is 67” wide encompassing the nose piece and the outboard channels, sits 9” from the deck and extends 5.5” forward from the nose piece.
- The Standard nose piece has a center opening for an oil cooler with 2 side openings for brake ducts. However, for my applicaton, I channeled all of the openings for radiator cooling for my Chevy. The openings measure 5.75” X 20.5” in the center with 2 other openings of 5.75” X 4.25”.
-Outboard of the radiator intake, I created my own front brake cooling ducts with an opening in the nose piece of 4” X 9” which feed to 5” ducts to the brakes.
-At each outboard side I created a 3.25” wide air channel with an acceleration ramp. The first intent was to create an integrated air control system between the splitter and the fender flairs, also from Rennspeed. While I was at it I added the airflow acceleration ramps as per common practice over the last 35 years.
-All work was carefully based on the time-tested Engineering Principle of “That Looks About Right.” Please refer to Mark Donohue’s “The Unfair Advantage”: “If it looks right, It’s Right!”
