Mike Knox
Apr 11 2010, 03:38 PM
I'm switching to LEDs all the way around, and was told to switch to a low powered flasher unit for the LEDs.
My 1974 has a four pronged flasher. Does anyone have a source for a low power four pronged unit? Or, alternatively, how can I make a three pronged unit work?
Thanks for any help!!
Mike
bandjoey
Apr 12 2010, 09:10 PM
NO LED for the alternator light, if you do the panel. It'll blow the alternator.
Take pictures and keep us up to date. I think lots of us are interested in bright lights.
montoya 73 2.0
Apr 12 2010, 09:32 PM
I'm using LED's except for the alternator indicator, Headlight and Fog lights. All bulbs are LED equivalent's. I bought mine from Mark "MIKEY914" in the Members Vendor area. I even got the flasher unit from him. Brighter than stock and should last for awhile longer.
underthetire
Apr 12 2010, 09:34 PM
You can always put a resistor in if you need it to simulate the load on the flasher. I did my dual sport that way.
FlatIV
Apr 13 2010, 09:22 AM
You may be able to buy one here.
Flasher
realred914
Apr 13 2010, 09:25 AM
QUOTE(underthetire @ Apr 12 2010, 08:34 PM)
ditto that, you have some abliltity to change flasher speed aslo with a selction of resistors. more current flow means faster flash
tracks914
Apr 13 2010, 09:46 AM
I was thinking of buying the amber ones for the front, clear for the back-up and red ones for the back.
Should be able to convert the whole car for less than $50.
Mike Knox
Apr 13 2010, 10:16 AM
Thanks for the help. That's a good site to have bookmarked!
Mike
underthetire
Apr 13 2010, 11:39 AM
I buy all my LED stuff through them. Never had an issue.
