I am about to install a David Lee flat tow bracket on my car. It is to be towed behind my motorhome on occasion.
The car is on the ground, wheels on. I pulled the allen head bolt that holds the front cap off and began to loosen the two bolts that hold the bushing carrier to the body. Then I thought I better do some research, having never removed a front torsion bar or control arm. Any reason not to simply remove the bolts and attach the bracket with the new longer bolts?
