So my transmission has been having issues. So out it must come. All went awesome not a single stuck bolt or rust issue. A true miracle for a 914 . However, the previous owner decided to relocate the battery to a box in the trunk. The box is welded in to the upper right corner and for the most part is out of the way in the trunk. However, it extends into the transmission area. So I start to pull the tranny and yep the housing hit the battery box after pulling the trans I cleared everything except the two bottom studs. I decided to use another nut and jam one so I can remove the stud. Worked great and transmission came out without a problem
