QUOTE(PanelBilly @ Apr 12 2010, 11:07 PM)
Put finish nails into the holes Nd then Lign the grills. Pull a nail out,put a screw in
.... first make sure that the push-in speed nut clips are in the round holes behind the carpet, & the clip-on speed-nut clips are on the tabs, & then start with the carpet one, then diagonal from that, then either upper or lower opposite, etc. to make an "X" pattern, like when you're torquing a head or something.
Don't re-drill - if the holes aren't lining up with the nails, then send them back to Morph for a better set with properly placed holes.
