See this is what I don't get, you will cut and hack a new wire in, ignition switch or whatever and yet knock this "patcher" who uses a Ford solenoid, who BTW has never ever cut an single OEM wire on his own cars. Ever.
On other cars I've repaired previous PO hacks, built new engine harnesses and made adapters so I didn't have to cut, but my 914 has a flawless harness and it is going to stay that way. I can remove the solenoid faster than I can change a starter, 2 nuts, a couple connectors done. Installs just as fast.
It's a incredibly simple voltage drop issue, all the relay does is boosts that voltage loss back up to 12v.
I did this for a living, I have quite of these "patches" running around. I use to tell customers that I'll mess with their wiring at $65/hr
straight time...or you can have a $35 installed solenoid. Also in almost 20 years I only ever had one come back, my wife's winter car, that solenoid failed due to corrosion.
But all due respect to the patchers. They fix lots of other problems in life too.... Can't get it up?? Need a crutch for cigarettes?? Yeah, you get the idea.
BTW I quit smoking, quit drinking, do a 20K bike ride through the hills every day, I'm the primary home school teacher to my 2 young kids, work on cars, building a chicken coop for my girl, post here and at a few educational blogs and I'm rebuilding my house... not to mention the fact I'm almost 49 and I have a 9" dick that's as hard as a rock.
What did you do today?
Oh and I forgot... I'm also passing a kidney stone, with no drugs, so I can be a bit irritable as of late.
But I'm just a lazy patcher
