blitZ
Apr 14 2010, 06:19 PM
Does anyone know where to get some replacements for our tiny dJet connectors? I did some googling with no luck. I'm looking for the female ends to patch some bad wiring, just need the metal pieces.
type47
Apr 14 2010, 06:30 PM
I found some of the small female spade connectors at a specialty electronics store and Radio Shack.
McMark
Apr 14 2010, 07:22 PM
Special multi-pin connectors? Or just normal spades?
blitZ
Apr 14 2010, 07:26 PM
QUOTE(McMark @ Apr 14 2010, 08:22 PM)
The small ones which go to every dJet connection. I just want some fresh metal pieces when I repair some wiring and slide back into the plastic holders.
dr914@autoatlanta.com
Apr 14 2010, 08:19 PM
QUOTE(blitZ @ Apr 14 2010, 05:19 PM)
the usual suspects always have them.
Tom_T
Apr 14 2010, 10:52 PM
... &/or try Jeff Bowlsby, as he gets them for his harness restorations somewhere!
Dave_Darling
Apr 14 2010, 11:56 PM
Rat Shack and possibly Worldpack distributors will have 1/8" barbed female spade connectors. Those are used in the injector plugs, the plug for the throttle switch, and a number of others.
Well, actually 3mm connectors are used. 1/8" is close but not quite perfect. I think I did get some 3mm ones at a different specialty place whose name now escapes me...
The 4-pin connector at the relay board uses 6mm barbed female spade connectors. I got some of those from VDO in a wiring kit or some such. You can get 1/4" ones (close to 6mm but not exact) at Rat Shack and other places.
--DD
MrKona
Apr 15 2010, 12:53 AM
You could try Vehicle Wiring Products in the UK.
http://www.vehicle-wiring-products.eu/VWP-...oninsblades.phpI've ordered from them before. They have a great selection of metric components and shipping was only about $10 from the UK, pretty fast too.
Tom
Apr 15 2010, 05:06 AM
rallylights.com 2.8 mm receptacle pt# HJ87271 box of 50 @ $14.00.
Susquehanna MotorSports
Tom
blitZ
Apr 15 2010, 06:18 AM
Good suggestions, I'll try Fry's and the Rat Shack. I was hoping to find some with the little metal strip to clip it back into the socket.
Thanks
Tom
Apr 15 2010, 12:27 PM
These do have the clip in back. The last time I ordered, they were on back order from Germany. The FI harness also uses other sizes. I got a few of all of the ones they carry to make sure I had some spares.
Tom
blitZ
Apr 15 2010, 01:09 PM
QUOTE(Tom @ Apr 15 2010, 01:27 PM)
Tom
I see them, just what I need, thanks...
