bought 1975 914 2.0 6 months ago- recently had dash gauges refurbed with LED lighting, ; went to put in new center console(from 914 Appearance and Performance)(car had one originally-some one took it out!) - wired everything up yesterday, but found the gray wires that should power the lights when switch is on do not have voltage!- no power - so the question is where do i look? at the light switch? or somewhere else- i also have no power at the license plate lights- is this on the same fuse and circuit??- I can hook them up temp. to the Red/white which comes on with the ignition, but this is no the long term solution.
Any Ideas?
