A couple questions on reinstalling windows on a 72.
1. The first photo shows a plastic "guide" that is glued to the rear portion of the glass. My problem is, my car has a rubber piece in the metal channel this piece rides in. In this photo there is no rubber piece. Which is correct?
2. Same question but for the front window channel guide. Do the roller pins ride inside a rubber gasket there as well? (item number 17 i've circled). My car doesn't have one, so wondering if I was missing them, or whether it might be what the factory started doing with the later cars.
I've found enough things on this car that have been put on backwards that I rather run this by you guys prior to reinstalling. Plus as it's a late '72 it has both early and late characteristics.
thanks in advance.
she's starting to look like a real car!
