Can anyone tell me where #23 goes? I can not find the download page for the wireing diagram. I don't know how I lost it, but it is cut now so I need the other end. I have the ECU end.
Thanks
-Pete
Mar 31 2004, 09:59 PM
i dunno if there's a difference between the years but my '70 (early) diagram sais:
wire #23 from the brain goes to:
(77) = Temperature Sensor II
which implies there's a Temperature Sensor I it's actually on the map too, Sensor I is in line between Brain Wire #1 and #13 ...
soooo, Sensor II it is, Andy
Bleyseng
Mar 31 2004, 10:04 PM
Isn't temp sensor 2 the CHT and temp sensor 1 is for the intake air temp sensor?
Mar 31 2004, 10:08 PM
QUOTE(Bleyseng @ Mar 31 2004, 08:04 PM)
dunno which one is which ...
but if only one connection is missing he shouldn't have any trouble finding the one that's NOT connected.
Andy
JeffBowlsby
Mar 31 2004, 10:56 PM
You all got it dudes....for aLL D-jet systems:
23 off the ECU connector is for TS2 = CHT sensor. look for a single white wire with a long blade male wire terminal.
1+13 are the TS1 connections....intake air temp sensor.
Bleyseng
Mar 31 2004, 11:17 PM
Yes Master
trojanhorsepower
Apr 1 2004, 07:47 PM
Thanks guys!
I was having trouble with that one, because I could not trace it. The harness is out of the car (along with everything else) and I am trying to piece it back together.
Thanks again
-Pete
