I like the idea of flow charts, but for the ignition sequence, there's a lot to review;
Battery (source of 12v)
Coil
Dizzy (electronic or Points/Condensor)
Dizzy (Cap, rotor, gap, timing, dwell, FI triggers)
Spark Plug Wires
Spark Plugs
Injector trigger wiring (from dizzy plug to individual injector plugs)
Grounds
Ignition circuit wiring
Ignition sequence (what does what, when. This is necessary to cut your troubleshooting in half, then trouble shoot forward or backwards from that point. Each time you make progress, yoyu again cut the problem in half)
Symtomatic reasononing (what the common indicators are for each type of issue).
The best flow chart I have seen is over at PBanders site:
http://members.rennlist.com/pbanders/FPChecklist_frame.htmEric Read
