machina
Apr 1 2004, 03:16 PM
I have these things on my fuel system, didn't realize that you just cut the hose, oil, and insert the end.
Are these things safe? Seems too easy.
I was planning on using these for my -12 oil lines.
dr
iamchappy
Apr 1 2004, 03:33 PM
They are great, I am using them on my 3.0 CIS engine to and from the gas tank, easy to work with and no pin pricked fingers the SS lines provide, I use a combination of both SS and socketless on my car.
machina
Apr 1 2004, 03:46 PM
Sounds great.
I am using the SS braid everywhere else, but the -12 lines that run from front to back are in the longitudinal with a battery cable. I don't want that ss rubbing on the battery cable, so the socketless hose should work out.
Glad to hear your having success.
dr
seanery
Apr 1 2004, 03:52 PM
I've been reading up on these since this post. How do they stay on?
machina
Apr 1 2004, 03:56 PM
You have to use the socketless ends with only the correct hose. The long barbs and the precise fit holds it all together, no clamps or hacksaws.
I'll be re-routing these fuel lines soon but this is what they look like.
dr
J P Stein
Apr 1 2004, 03:59 PM
I dunno bout the socketless stuff.
Buy some and pressure test them up to 200 psi (or so) while applying heat to em'......for a couple hours.
machina
Apr 1 2004, 04:08 PM
Aeroquip already did that.
Assembly rated at 300deg continuous at 250 psi.
The AQP has the same temp rating but a much higher pressure margin, 500 => 1000 psi.
Jake said he has seen 300psi on very cold startup but I think the socketless is probably OK for a racecar, maybe not for a race airplane.
dr
