Some of this stuff isn't making sense:
It is one that I had to change out the ball unit, no spacer needed.
If you change the ball you are changing the depth of the ball in the tunnel. If you do that, you need the spacer to bring it back up to the stock parallel geometry. Otherwise it rubs the bottom of the tunnel and binds in the rear bushing... no?
Likewise:
The Weltmeister has a plate that lifts up the base of the shift console making the linkage do things a touch different than it is suppose to.
The plate is the depth of the new ball so, the plate does not make the linkage do anything different than it is suppose to. It makes it go back to doing what it is suppose to. Add the ball = Linkage now angles down. Add the plate = Linkage is back to where it's suppose to be. No?
Regarding:
I don't see where the console would be affected by the type of shifter - but I never had a console and a shorty at the same time.
The factory center console is fitted right along the left side of the shifter base. The Weltmeister spacer has a buldge along that side that would have to be machined (ground) off in order for it to work with a factory console.
After going to Evil's tranny clinic, I found the first gear dog teeth trashed in both of my trannys from brute force shifting.....
I think kwales hit's the nail on the head except, these aren't "speed shifters" they just shorten the throw. These came to market with years of people complaining about the long vague shift motion associated with these shift consoles. If anything these short shifters reduce the leverage exerted on the tranny and linkage... they just engourage bad behavior.
The real issue is the nut holding the steering wheel, people do not shift a 901/911/915 the way they were intended as he mentions. It's common and could be one of the most important pieces of information in this thread or on this site regarding saving your tranny. As new drivers are introduced to these old cars, this seems to be a lost art. Speed shifting an early syncromesh tranny involves double clutching which speeds up the syncros faster than the mechanism itself does. When installing a short shift kit it simply tends to accentuate the fact that people do not shift them properly. Most will get in their car after the mod and head down the street to see how fast they can hit the next gear. Bad.
Do what he mentions (I'll modify this a tad):
Shift out of gear, press the lever to the gate of the next gear (engaging the syncros), wait for the synchros to speed up, and and then shift into gear.
...and your tranny will probably outlive you (short shift kit or not).
