OK,
Mine is now complete, but the Nut Plate theory anchored by rivots does not work, too loose, and this does not mount the foglight flange flush to the mounting position. You need, as said above, the clamping power of a bolt/Washer/Nut combination.
After way too much thought, there is a way. Use the methods described above to locate the position for the bolt to hold the foglight flange. The "X" works well, mark the spot ...then put the bumper and grill back in position to confirm exact location.
Here is the trick part, drill your hole into the abyss below the headlight, where your Foglight will mount. Take out the spare tire as this will become your work space, there is a small slit about 1 to 2 inches wide where you can see into the opening in which you have just drilled. This would be best with two people, I did it by myself in about an hour after I dropped the washers 4 times. (once on the drivers side and three times on the passenger side). Have your helper mount the light and bolt through into the area that is not accessible, take a piece of coat hanger cut it to 8" and hang your washer on it. With a flashlight work the washer in place and hang it on the bolt. If you drop it take your time grab it again and retry, it is not impossible just another Porsche challenge. Once the washer is on the nut, grab two 3/8" ratchet extentions and put two universal (Knuckle) joints on the end and your shallow socket to fit the nut. Take tape and tape up the universals too fit the angle you need, all you need is to get the bolt and nut started. Once set add a socket, put a spacer nut in the bottom with a piece of tape to hold the nut about half way out of the socket, but in a position that will not let it drop out, taped from inside of socket. Once everything is in place you can hold the rachet with your left hand and thread the bolt with your right. Once you get the bolt and nut started... this was actually the easiest part you are in business. You can just reach the nut with a wrench to tighten down. This was a great challenge but everything ended up really secure and strong. Way too much thought though.
I'm glad it finally fits the way I wanted it to.
Vysoc .................Pictures to come
