I wish I had known this was a possibility up front, I might have gone a different direction. I don't dare remove those hubs now.
Did you buy the hubs from me? I "always" try to have a more thought out and thorough discussion with people buying my hubs. I searched my records and only show the Elephant stuff on the books. Those are excellent hubs for a 914 to 140hp. That said, I've actually talked more people out of buying them than I've sold. I can think of a couple V8 guys in the last month alone that I've pointed to a heavier CV solution, one that I don't even sell. Again, there's nothing wrong with the hubs but, you'll be limited to 914 CV's. What engine is in that car? Check the 5-lug thread. Now's the time to make a switch before you go deeper:
http://www.914world.com/bbs2/index.php?showtopic=105728I have a couple sets of 911 hubs coming in if you want them. Then you'll need about $500-700 worth of CV's, axles and flanges (those are coming as well) and you'll still have a problem with these rotors if you're using the -4 calipers.
4mm off the diameter if you decide to go with these hubs or the 911 hubs. Again, it's the 914-4 caliper that will be a tight fit on those -6 rotors.
If you bought the rotors from me you can send them back. If not, sell them and buy the -4 rotors... I can take those to the machine shop and you're done. I don't think you got the rotors from me though. I usually would have talked you through all of this.
I see a simple solution. People will always be in the market for a new pair of -6 rotors. Sell them in the classifieds. Spring is a good time. Use the money to buy drilled 4 rotors.
You're almost there. It's a rotor issue.
