Prototype billet swaybar setup for the front of a 911 or 914. $200.00. This is compatible with a Tarett engineering bar and nut plates. With shims you can use it with a stock bar, GPR has the shims. It needs a bar, teflon bushings the right size for your bar, either from Tarett or GPR for a Tarett bar or whatever size you need for your stock bar from McMaster-Carr and a set of nut pates for the back. A Tarett complete setup is $475.00. This way you can get the nut plates for $25.00, the teflon for about $20.00, and a bar for around $100.00. The last time I talked to Ira at Tarett, about a month ago, he said he had some bars with discolored coatings for $100.00. Discolored coatings don't matter if it's under the fuel tank, do they?
So, you'll have a bar as good as a $475.00 setup for under $350.00.
That's what I call a deal.
Steve
(805) two one five, 0243.
Here's a link to Tarett- http://www.tarett.com/items/914-products/f...ba22-detail.htm
