xsurfer
May 3 2010, 06:14 PM
Hi Guys!
The clutch cable is hanging loose clear of the arm it attaches to, after a sudden let go. Did I loose a throw out bearing or bend and arm?
Any ideas. Car is bone stock! 88k orig. miles. HELP!!!
Thanks
Gene
Spoke
May 3 2010, 06:26 PM
Could be a number of things as you mention the throwout bearing, clutch fork, or if there is rust, the clutch tube.
xsurfer
May 3 2010, 06:29 PM
QUOTE(Spoke @ May 3 2010, 05:26 PM)
NO RusT! I've had it on a rack numerous times. I'm thinking T.O. Bearing but never had one go bad. Clutch cable replaced before I drove it home.
Spoke
May 3 2010, 06:40 PM
I had a new clutch cable go out in about 1 years time. Kept stretching and stretching, I adjusted and adjusted, then...SNAP
PRS914-6
May 3 2010, 06:42 PM
Check to see if the clevis broke that attaches the cable to the clutch pedal
xsurfer
May 3 2010, 08:16 PM
QUOTE(PRS914-6 @ May 3 2010, 05:42 PM)
Tomorrow late afternoon I can look under the car. Just curious as to what others have experienced, helps looking for what you don't expect.
Thanks
Gene
xsurfer
May 3 2010, 08:17 PM
QUOTE(Spoke @ May 3 2010, 05:40 PM)
I can only hope it's the cable!~
May 3 2010, 08:22 PM
QUOTE(xsurfer @ May 3 2010, 07:16 PM)
Make sure the clutch tube hasn't broken lose ...
If there's any play in the tube, one of the clamps has snapped or maybe even cracked the rear firewall around the tube.
Andy
xsurfer
May 3 2010, 08:30 PM
QUOTE(SirAndy @ May 3 2010, 07:22 PM)
Andy
I'll check tomorrow. Has anyone ever bent the arm? It felt mechanical when it let go.
Thanks
Gene
GeorgeRud
May 3 2010, 09:46 PM
If it let go all of a sudden, I'd first look at the clutch clevis pin, as the original ones were made of some type of plastic, and the little pins on the side would shear off. There are replacement ones out there made of metal that solve this problem.
dr914@autoatlanta.com
May 4 2010, 08:04 AM
Andy
I second Andy's opinion. I think that is what has happened. Look first up front to the left of the shifter hole and a bit forward where the clutch tube attaches to the inside of the shift tunnel. You will need to remove the shifter and the clutch cable. Then grab the tube (is is the larger lower one) and shake it. If it is loose there is your problem. The repair procedure is well documented in the "Tech Tips 700"
PRS914-6
May 4 2010, 10:07 AM
QUOTE(dr914@autoatlanta.com @ May 4 2010, 06:04 AM)
Andy
It would seem unlikely that it's the tube because he stated the "cable is hanging loose" which would take something pretty bad to generate that much slop in the cable, perhaps the clevis as I mentioned, broken cable etc. I don't know if the tube broke if it would cause that much slop. The inner cable would still be attached at both ends. Can you get that much slop if the tube totally breaks? The peddle gets mushy for sure.....
PeeGreen 914
May 4 2010, 10:50 AM
QUOTE(xsurfer @ May 3 2010, 07:30 PM)
Andy
Thanks
Gene
Those arms are stout. Good luck bending that. I'll agree with the others that said clevis. Hard to say until you really get in there and look.
All in all, no matter what it is they are all fairly simple fixes. Don't worry about it too much. We will help take care of it
May 4 2010, 10:53 AM
QUOTE(PRS914-6 @ May 4 2010, 09:07 AM)
Yes, you can. Happened to me ...
Andy
xsurfer
May 7 2010, 09:07 AM
Thanks to all. The clutch cable is good! Time to take the motor and trans out for some service.
Rats!@!!! Ah Fudge.
