my brakes were beyond questionable and i just rcvd 4 of the 5 rubber lines i ordered from pelican and installed them. 5 lines you ask - yeah - i replaced my proportioning valve with a tee and used a rubber line there too but it needs replacement with a rubber line now and the reinstall a proper prop valve asap.
anyway - my tires now SQUEAL under hard braking : ))))))))
btw - i use a motive bleeder to bleed by myself and will altrnate between blue and amber ate fuild at each flush, from eric shea.
