QUOTE(ClayPerrine @ May 5 2010, 11:20 PM)
Easily done.
1. take the tail housing off the tail shifter and set aside.
2. remove the tail housing from the side shifter, extract the gear stack and remove the shift rods and forks.
3. install the shift rods and forks in the gear stack from the tail shifter. Adjust the shift forks.
4. install the tail housing from the side shifter onto the tail shifter.
5. Install the shift console.
6. Enjoy.
I suggest that you replace all the gaskets and seals while you have it apart.
Thanks for the info. Didn't know it would be that easy!
