QUOTE(jim_hoyland @ May 6 2010, 07:36 AM)
What happens when the tach wire is attached to the + side of coil instead of - ? Does it cause permanent damage ? Reaon I ask, I've taken apart two ignition harnesses and found the tach wire covering melted even though it was deep in the harness.
Try a PM to the "Harness-meister" Jeff Bowlsby, since he's seen so many, & he may know?
