QUOTE(ClayPerrine @ May 6 2010, 10:29 AM)
On a 911, it is pushed by the cable sheath. Most of the 911 ebrake conversions only pull one side. I don't know if this one does or not.
Ok, that makes sense. The second butterfly is redundant. So here's my thinking...
Without the sheath to push in against the inner butterfly, it will not move inward, thus when the shoes spread apart, the inner butterfly's "wings" will fall out of position and just dangle.
Here's my plan then... tell me if you see any holes.
This is the 40mm spacer bracket that Tangerine provides. There were no instructions in the kit, though from the pictures on the Tangerine site, it appears they were intended to be welded onto the trailing arms. (I think I prefer the method Eric Shea used... of welding it the e-brake carrier, so the entire e-brake can be removed as one piece. I'm referencing the thread of his in the Classic's section)
Click to view attachment So the butterfly actually serves two purposes... in addition to spreading the brake shoes, it provides a seat for the spring that floats between the two butterflies. The wings will just dangle, so my plan is to cut off the wings...
Click to view attachment Then weld the "maimed butterfly" to the Tangerine bracket.
Click to view attachment Continued on next post...
