QUOTE(tomeric914 @ May 7 2010, 08:43 AM)
Both rotors will work but there will be a slight advance in timing. If you're running an 009 at 28 deg, you may be at 30 deg with the new rotor. Worth a quick check.
really????? I thought timing was controlled by that thing called points or maybe an electronic ignition. the spark fires when the pioint open, either the rotot is in postion for the spark to jump to the cap terminal or not. the length of the contact area on the rotor should have no perceptable effect on timing advance or retard.
Note how you can move the cap on the dizzie even when it is locked down, got to be a couple degrees of slop there to, yet that has no effect on timing.
the spark goes when the points open regardless of where the rotor is. either the rotor is in postion to allow the spark to jump to the cap or it is not. But the timing of that event is controlled by the points, not the rotor nor cap position.
I supsect you have two style of rotors with differenbt design of tips. (dispite same part numbers. If the difference was from wear, there would be a lot of arc welding style melted metal all about.
