When I press my brake pedal, the little plate that holds the clutch/brake stop moves a little bit. It's pretty annoying.
I dug into it and there is a nut that attaches that plate to the pedal base. I snugged it up and no improvement.
I think if I install a bolt on the front of that plate through the base, the issue will go away. But, I wanted to get input from the group before I bust out the drill.
the pedal cluster appears to be in good repair otherwise, bushings are brass and the parts don't have any rust to speak of.
does anyone else experience this? how did you fix it? (or do you just live with it?)
Pics:
