QUOTE(Bartlett 914 @ May 7 2010, 05:27 PM)
QUOTE(detoxcowboy @ May 7 2010, 07:14 PM)
They are dim by nature, especially in daylight but even so at night. Clean the blue lense, add a new bulb or even led ect.. I would not trouble over it so much..
I was thinking maybe it was supposed to have a higher wattage bulb or maybe putting in an LED. It is way too dark, I don't think it is normal.
If all the rest of you gauges are bright? Drop an led in, but led's are either on or off not dimmable by the dimmer switch. also check/clean your gound up to the left of the fuse
box, I have had 2 914's and compared to say a 90's FORD FOCUS
they are dim. Also the jumpy tach can be fixed cheaply at Hollywood VDO, they put a supressor inside.. completely resotored all my gauges, even had an nos tach at one point.. still dim.. 1970's tech. Also can switch bulbs with say your tun signal lamp if you think the bulb is the issue ect..
