QUOTE(Cevan @ May 8 2010, 05:26 AM)
Use new copper gaskets ($3 each) and anneal them with a propane or Mapp torch to soften them a little. To make sure the ends of the HEs are perfectly flat, use a large file to file across both ends at the same time. This made a huge difference in the way mine sealed.
Cevan, listen to Cevean Aneal the copper gaskets.. if you do not have a torch put them on your gas stove top. This willl help them seal/ this made a huge difference for me as well... If they do not seal right your gonna hear it..
Oh, the worst thing you can do on this project is break an exhaust stud off your cylinder heads!! Be extra vigilant around those, do not over tighten or tighten up while crooked or not seating propererly..
