> By the way what kind of a 916 rear transmission tail cover is that?
Vellios
> aftermarket heat exchangers and an aftermarket muffler
Yes, B&B (I think) headers with heat, and M&K sport muffler.
> Take the exhaust off the car and use a table mounted belt sander to resurface the flanges
Thanks for the tip. I took it apart yesterday, and used a belt sander to flatten the flanges. Just by looking at the ends they did look dead flat, but when I sanded/polished the flanges, the tips did polish first. There was so little taken off I'm not sure if that was the problem, but it did make for a nice shiny surface to bolt everything back together.
> What muffler gaskets are you using ? I have a 3.0 in mine with headers and a M&K muffler and I'm using the gaskets that have copper foil on both sides. Bought them from Pelican parts.
Yup, I'm using the same ones. Just standard <73 911 muffler gaskets.
We'll see what happens. It's back to just being loud again, and hopefully it lasts, but I'm not so sure.
I wonder if the old (< 73 gaskets) aren't just up for the heat and back pressure generated by a 3.6... ?
This type of design seems to make a lot more sense:
http://www.jegs.com/p/Dynatech/Dynatech-V-...753318/10002/-1Or like was mentioned, even if there were 3 bolts per flange like the later 911 mufflers:
https://www.sierramadrecollection.com/store.../2925_small.jpg-Steve
