QUOTE(rfuerst911sc @ May 9 2010, 10:55 AM)
QUOTE(realred914 @ May 9 2010, 09:50 AM)
urathane or simular makes sence to help water proof them paper board parts, specially near the floor. that is a very very good idea, I am embarised I did not think of that for my self. good idea actually!!!!!!
make darn sure you rear window is fully sealed to keep water out of that spot!!!!
nice idea!!!!!!!!!!
So you agree poly would be good to keep water out ( if any ) and will probably make it stronger also. My rear window was glued in last year by a glass pro so no leaking there.
yup, I'd avoid doing fiber glass as that will stiffen it a good deal, and may make it so it wont fit right. the paper board even with a water proffing will still remina near as flexable as stock. if you do glass over your paper board, best to make sure it is the exact shape you want it to be before teh glass takes on a set as it cures. that would be the "trick" in making a fiberglass part or covering the stock part, making it lay just right in the car.
