JoeSharp
May 9 2010, 11:48 AM
Where does the brown and white wire go that comes from the turn signal and high beam switch, on a 70 914-6?
Mike Bellis
May 9 2010, 11:50 AM
QUOTE(Joe Sharp @ May 9 2010, 10:48 AM)
Horn relay?
JoeSharp
May 9 2010, 12:26 PM
So I hooked up the trouble light to the wire and could not get it to show me the light. All of the lihgts work fine and no signal there. Just going to tape it off somewhere and go to the WCR.
ClayPerrine
May 9 2010, 07:40 PM
IIRC it doesn't go anywhere. On the 911, where they got the switch, it was wired to power, so that when you pulled the turn signal switch, the high beams would flash.
Do this... hook up the test light to it, and see if it gets power when the high beams are on and you pull the switch......
JoeSharp
May 10 2010, 05:48 AM
Thanks Clay, went there did that. I think Mike is correct. I figured it out at 4:20 this morning. It's to early to test it out yet. I was thinking about all the other stuff and since the horn worked before I didn't evan think about it.
ClayPerrine
May 10 2010, 12:44 PM
QUOTE(Joe Sharp @ May 10 2010, 06:48 AM)
If it goes to the horn relay, you should be able to hook a test light to it, and hook the other end of the light to power. Then push the horn button and make the light flash.
JoeSharp
May 10 2010, 03:34 PM
Yes and I would have if I were thinking about the horn at the time I was doing the testing. Now that I have driven the car I have done the real test. Everything works.
Thanks
