1974 Porsche 914-4 Race Car
Built for POC V-5 R-7 classes, always wins
SCCA legal, PCA, NASA
Top speed with current gearing, 138mph through turn 8 at WSIR
Fully developed reliable racecar
Engine-
2 liter built to a 2056 with 10.5:1 compression 96mm forged JE pistons and steel cylinders
Webcam 134c full race camshaft
38mm & 48mm valves
Ported & polished heads
High pressure dual valve springs
New silicon bronze guides
Weber 44mm IDF carbs with aluminum K&N air filters
Counterweighted, knife edged crankshaft
Rebuilt, shot peened rods
Super lightweight flywheel (7#)
Stage 3 pressure plate
Lightweight 6 puck clutch
Accusump oil accumulator
Deep oil sump hold 2 extra quarts
Front & rear oil coolers, NEVER gets hot, even in the desert in summer
Custom crankcase venting
Less than 20 hours on the engine
Transmission-
Completely rebuilt with M-S-X gears
All new bearings, gaskets, and synchros
Shifts flawlessly, utterly reliable
Less than 20 hours on the transmission
Brakes-
"M" caliper vented 911 front brakes
Brake cooling ducted through the body
Larger rear calipers
Porterfield R-4 pads all around
Brake bias adjuster
19mm master cylinder
All calipers rebuilt with 0 hours since
All rotors just resurfaced
New wheel bearings with less than 5 hours on them
Suspension-
Bilstein shocks and struts
Front camber plates allow plenty of adjustment
Turbo tie rods
23mm F torsion bars
225# rear springs
19mm F swaybar
Converted to 5 lug wheels with Porsche studs
Hoosier DOT race tires
Spare set of Hooiers
Chassis
Stripped down, only 1880# without fuel
Full cage
Fuel cell
Flared rear, fits 8" wheels with 225/50 or 245/45 rear tires
Momo steering wheel
Momo shift knob
Safety
Current 6 point Crow Racing seat belts
Monaco racing seat, mounted low, adjustable
Window net
AFFF fire system
This car is fast & fun. Nothing but 1st place trophies.
At the track, guys with much much more expensive cars will ask "why are you so much faster than me?".
Similar on track speeds to a prepared C-2 or C-4, 993, New Cayman on similar tires.
You can be really fast for little money!
SOLD!
