GTeener
May 11 2010, 05:24 PM
OK, so my "bonus" 914 is a stock 2.0 engine. I drove it to work once. Parked it on the street and covered it. It rained a couple days past and I was out of town over the weekend. I took out the trash last night and noticed a dark puddle coming from under the car (rear right side) seeping to the curb. I was warned there were leaky seals but told it was drivable.
So my question is, how much of a leak is too much?
Do I just put some 20/50 in every time I go for a drive?
I assume the 4-cyl 2.0 engine oil also needs to be checked while the engine is running
SLITS
May 11 2010, 05:31 PM
Gwen .... oil is checked, car sitting level, not running. There is no oil tank, just a sump.
What's to much? A drop of oil spreads out pretty far. Leaking seals may be the pushrod tube seals or valve cover gaskets.
Put oil in it when it's low and drive it till those items can be replaced.
So sayeth Shitzzz.
GTeener
May 11 2010, 05:41 PM
QUOTE(SLITS @ May 11 2010, 04:31 PM)
So sayeth Shitzzz.
OK. I'll go with that story
Ah! Not running....not like the 6-cyl. Thanks!
20/50 oil OK?
Approx. how $$ is this kind of repair on average?
SLITS
May 11 2010, 05:44 PM
20-50 is perfect. If anything but the "approved by World Members" oil, I add sufficient Lucas Oil Additive to get the "good wear additives".
One member had a cut seal on the oil return tube at an event. Everytime she parked it, it would drain about 1/8 quart on the ground. Bought a case of oil from the return home.
Just watch your oil level.
GTeener
May 11 2010, 05:49 PM
QUOTE(SLITS @ May 11 2010, 04:44 PM)
Understood.
sww914
May 11 2010, 05:52 PM
Rich Towle determined that one pizza box per week's worth of dripping or less was an appropriate amount. He was unclear about what size of pizza or what toppings were included.
SLITS
May 11 2010, 05:55 PM
Pushrod tube seals and valve cover gaskets wouldn't amount to much ... I forget ... maybe $15.00 total.
What the mechanic charges is another story. Valve cover gaskets are a snap to change. Push rod tubes are a bit time consuming because the rockers have to be removed. Not a hard job at all.
Jeffs9146
May 11 2010, 06:06 PM
Also check your oil sending unit!
underthetire
May 11 2010, 06:57 PM
Go ahead and
me but..
My car leaked about 10 drops every time I parked it, so i put some of that high mileage synthetic blend in it. Said it has seal softener in it, i believe them. Down to one drop now, no oil burning to speak of. Worth a shot IMO.
And i do recommend doing the valve cover gaskets. Super easy. I silicon the gasket to the cover then put them on.
r_towle
May 11 2010, 07:35 PM
Joke away big guy....
If you put a pizza box under it and it does not last a week without turning into a wet mess that you need a shovel to pick up...you need to fix the leak.
Look it up, its in the original italian owners manual
Rich
detoxcowboy
May 11 2010, 07:45 PM
Curious on the 20/50 weight? I just read the manual and it states 30weight over 32 deg. F 20weight from 5deg.-32deg. and 10 weight under 5deg...
I have been running 30 weight for 2 years, so. cal. w/ no leaks..
is the 50 weight for when you can't fix the leaks?
Love the Pizza Box evalution, actually amkes alot of sense in estmation..
SLITS
May 11 2010, 07:53 PM
Multigrade oils supposedly are easier on the engine on a cold start and change viscosity as heat is added.
Do whatever turns your crank ...
Spoke
May 11 2010, 08:20 PM
Is the car usually parked on a road with a big crown? The original pic looks like it does. If the engine has a leak then parking on a slant may make it leak even more. Maybe the leak is only on the passenger side. Park the other way and it might not leak as much...
ArtechnikA
May 12 2010, 05:34 AM
QUOTE(detoxcowboy @ May 11 2010, 09:45 PM)
Curious on the 20/50 weight? I just read the manual....
That would be the manual written 40 years ago for new cars...
If you have a new car and a supply of 40-year-old 30-weight oil - go for it.
Today's oil is different, and (probably) your engine has a few miles on it.
We must adapt...
detoxcowboy
May 12 2010, 06:30 AM
QUOTE(ArtechnikA @ May 12 2010, 04:34 AM)
We must adapt...
I guess I should correct myself, I have been using 10/30 w/ no leaks for 2 years daily driver.. You can get straight 30 wt. Brad Penn but I have never used it.. pretty much been using synthetic 10/30 Lucas but have some Brad Penn 10/30 in my garage for the next change. I understand that Oil is debate able subject but did not want to start off over again. Also agree w/ pizza box and "whatever turns your crank", just was trying to make sure I was not causing my self a problem, in addtion I will be in Montana not So. Cal. by winter time and know I should make some changes for the freezing temps.. Thanks for your input.
PeeGreen 914
May 12 2010, 10:43 AM
I have a question on the size of pizza box. I always buy extra large pizzas. So is this the right size or are you talking about the personal pizza size
I need to plan these things for when I have a four
70_914
May 12 2010, 12:10 PM
QUOTE(underthetire @ May 11 2010, 05:57 PM)
Go ahead and
me but..
Seal softener is usually bad. Yes, while you are running the oil it softens the seals. After it wears for a while the seals get hard again, and most times harder than before.
Think of the seal softener as kerosene or thinner- it does not last as long in the engine as the base stock of the oil.
I would not recommend running a bunch of oil additives or oil with additives already put into it.
Root_Werks
May 12 2010, 01:33 PM
QUOTE(sww914 @ May 11 2010, 04:52 PM)
So that's what I've been doing wrong. This whole time I've been using a regular cardboard box folded up.
Pizza box it is.
GTeener
May 12 2010, 03:52 PM
QUOTE(Spoke @ May 11 2010, 07:20 PM)
I see no crown. But no. This is not a picture of where the car is currently parked.
GTeener
May 12 2010, 03:56 PM
QUOTE(r_towle @ May 11 2010, 06:35 PM)
Rich
Just got recycled yesterday morning. I'll try a different box flattened.
EdwardBlume
May 12 2010, 04:18 PM
Cars that have sat awhile can leak pretty good. Synthetic oils are thinner and leak more too... you just want to see what the leaks are, where they are coming from and reduce the seepage if possible...
The 2056 I just installed has rouughly 5K miles, hasn't dripped anything yet, but its got a good layer of oil underneath...
r_towle
May 12 2010, 05:31 PM
QUOTE(Phoenix 914-6GT @ May 12 2010, 12:43 PM)
It really wont matter on your minvan
The box always comes primed from the pizza shop...so its ready for more oil.
Rich
SLITS
May 12 2010, 06:03 PM
QUOTE(r_towle @ May 12 2010, 04:31 PM)
Rich
Yeh Rich ... squeeze the pizza for a full 12 quart oil change on a six.
PeeGreen 914
May 13 2010, 09:44 AM
Rich
Minivan? Oh nooo... not me
EdwardBlume
May 13 2010, 10:19 AM
QUOTE(Phoenix 914-6GT @ May 13 2010, 08:44 AM)
Rich
PeeGreen 914
May 13 2010, 10:24 AM
Google maps: 8926 Whitechuck Dr, Seattle Hill-Silver Firs, WA, United States
Address is approximate
Now would someone with those cars and a 914-6gt go to a minivan?
GTeener
May 13 2010, 12:09 PM
GTeener
May 13 2010, 12:10 PM
charliew
May 13 2010, 12:20 PM
That looks like about three tablespoons probably whats in the valve cover when you stop it. First stick your finger tip in the oil and smell it. Then smell the oil on the dip stick. If they smell the same it is motor oil, if not it is trannsmission lube. I think the pass side valve cover possibly is really bad. It needs attention now but check the oil on a level surface after you make sure the oil is on the stick before you start it up the next time. Also the oil sender is a good place to check and the oil cooler area.
Spoke
May 13 2010, 12:27 PM
Now that's a puddle!
PeeGreen 914
May 13 2010, 12:32 PM
Is all that from one time parking it or a few times?
Most likely not as much oil there as you may think but still disconcerting I'm sure.
GTeener
May 13 2010, 02:35 PM
QUOTE(Phoenix 914-6GT @ May 13 2010, 11:32 AM)
One time driving. It's been sitting on the curb since because it was raining a bit and I've been too busy the rest of the time needing my wagon.
Ferg
May 13 2010, 02:39 PM
That would be to much
did it leave a trail as you pulled in?
Time to figure it out before you drive it again, check oil before you run it again, top off oil and start it up, you should be able to SEE that leak as it happens.
Ferg
Root_Werks
May 13 2010, 04:42 PM
Too much! Even if it was a week.
Taco plate and push rod tube seals, cheap and pretty quick to do. Also oil sending unit. Cheap.
Then see how things are. All those are cheap enough and could use replacing anyway. So even if it only fixed 20% of the leaking oil, no harm done. I bet those three items would fix most of the oil leaks though.
Harder stuff would be the rear main, oil cooler and filter console seals.
Were's that oil slick smiley?
underthetire
May 13 2010, 04:53 PM
Way too much! You can actually get a big fine here for that much. No oil down the storm drain. That needs to be fixed.
GTeener
May 13 2010, 05:06 PM
Ya. I figured it needed to be fixed at some point. Seems like sooner than I hoped. So glad to hear that they should be cheap and easy fixes (for a change).
Stupid me didn't think to ask the PO when he said "There are some minor oil leaks but it's a solid daily driver" to elaborate on what exactly those minor oil leaks entailed. He didn't care about this engine because he was going to put a V8 in it. But then he lost interest with so many other cars and projects.
PeeGreen 914
May 13 2010, 05:20 PM
Yeah, I feel for people like that
Wish I could come down and help. I like projects
. A few of the local guys are going to keep me busy here for a while though
GTeener
May 14 2010, 07:05 PM
Tom Amon did me the favor of looking under the car and assessing what is leaking. He says the "taco plate" is fine. Transmission is dry. He says the valve gaskets need replacing & a lot of brake cleaner to clean up the current mess.
EdwardBlume
May 14 2010, 07:21 PM
QUOTE(GTeener @ May 14 2010, 06:05 PM)
That's a lot of oil. Valve cover gaskets are easy though. With that much, the oil leak should be easy to find...
914s that sit and then run... leak..
