Trying to figure this out. I'm currently running a Bursch exhaust on SSI exchangers on my '76. Stock FI. I want to install the O2 sensor and my AFR gauge kit, but I also want to switch to a better exhaust than the Bursch. My research tells me that the stock is hard to beat, except for price... Bursch is too raspy for my taste. When I wind it up it sounds like my 2 cycle leaf blower...
Depending on the internal layout of the stock (or Dansk?), I suppose it would be possible to weld the bung onto the body of the muffler at the first stage where the left /right mixing and initial expansion takes place. What do you guys think about that? And does anyone have a diagram of the 4 cylinder Dansk or OEM (if different) internals? I found cut away views of the early 911 Dansk. Is that similar?
Thanks,
Jim
911 Dansk diagram
